LabWindows/CVI
matlab
I want to execute the "open" command in CVI to open a file which existes in Matlab .
How to use "MLApp_DIMLAppExecute" function to carry out my idea?
My CVI version is 7.0 and my Matlab version is 6.5.
Thanks for your help!
(4,004 Views)
Hello linfeng413,
I would suggest taking a look at the Matlab ActiveX shipping example located at \samples\activex\matlab\matlabdemo. If you open the matlabutil.c source file, you will see a function that uses the MLApp_DIMLAppExecute function. This function is called RunMatlabCommand and should be a good starting place for your application.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,980 Views)
But now I want to know if the use of this function have something to do with whether I have installed the Windows SDN in CVI.
If I have not installed it ,can I use the function correctly?
(3,969 Views)
Hello linfeng413,
You should be able to use the function independent of whether or not you have the Windows SDK installed. What you need is Matlab installed, and if you have problems running the Matlab shipping example, I would suggest recreating the Matlab ActiveX controller by going to Tools >> Create ActiveX Controller.
Thanks.
Wendy L
(3,960 Views)
Thanks for your help very much !
With the method that you provided,I have solved the problem perfectly !
(3,951 Views)
