LabWindows/CVI
mbslen not found
I want to get a Statemate executable running on my PC which uses some functionality out of Labview (I don't exactly know which features are used).
First I received the error message that "cvirte.dll" was missing. I then copied that Dll into the right folder.
Now when I start my executable I get the error message "entry point of procedure "_mbslen" in DLL "dvirte.dll" not found".
Any idea what the problem could be? Happens on Vista Ultimate 64 and Win XP 32
(3,766 Views)
It seems your program need for some reason the CVI Run-time Engine to work; instead of simply copying the dll to disk, to have it working correctly you must install it downloading the correct release from this page.
(3,756 Views)
even after installation of the runtime I still have this problem.
Any other idea?
(3,741 Views)
(3,692 Views)
