LabWindows/CVI
measurement Studio break teststand
mesurement studio breaks on every string value test of TestStand
(3,295 Views)
In order to help you with your question, we will have to know more about what is happening. Please post a specific question with a detailed problem description. It would be helpful to know what development environment you are using, what version of TestStand, and the exact error information.
Thanks!
Shannon R.
(3,295 Views)
Ok I will try to describe my problem. i'm using the couple teststand/measurement studio. the cvi test routines are run with teststand. every time when i use a "string value test" step in teststand my cvi routine is stopped before the routine itself runs. it behaves like there is a break before the routine is called out of tscvirun_supp. other steps like "numeric limit test" will not break. maybe something in my configuration is wrong.
my win system is NT40.
(3,295 Views)
