LabWindows/CVI
memory full error when using labview
I recieve a "memory full error at node..." pop up error when running one of my sub vi's. The sub vi used to be part of the main vi, I did not recieve the error then, but I put it into a sub vi to clean up the code, and now I'm recieving the memory error. I watched the progresion of the code using the light bulb icon and the error didn't occur right at the new sub vi, but inside of one of the sub vi's sub vi... the exact location of the code, when the error occured, was when the information got to a for loop. My machine has plenty of extra memory, so I don't really understand what the error is for. Any help on this subject would be greatly apreciated
(3,209 Views)
John,
I think a bit more detailed information about the application and your system might be helpful. Are you using LabVIEW for Windows and what version? Are you using NTFS by any chance or trying to do TCP/IP or GPIB applications? Are you plotting data inside the For Loop?
(3,209 Views)
