LabWindows/CVI
memory leak in CVI ?
I am using TestStand 1.03 together with LabWindows/CVI 5.5.
I detect memory leak when I post UI messages from my DLL to the UI - It seems to leak in the message callback routine in CVI - Has anybody any idea what seems to be the problem ? I'm calling CA_FreeMemory for every char* that I read from the Engine.
/Mats
(3,374 Views)
There are two KnowledgeBase documents that talk about the possible reasons for memory leaks with TestStand and LabWindows/CVI. Those documents will give you some ideas.
http://pong.ni.com/public.nsf/websearch/EFA67CCC5836BC8586256BE60062C3D8?OpenDocument
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/3a6899738157ea8986256ac5004bc0a7?OpenDocument
Mika Fukuchi
Application Engineer
(3,374 Views)
