LabWindows/CVI
mesa.dll maybe out of date
When I running a program, the error will be exposed " the function is not found , mesa.dll maybe out of date"?
how can I solve it?
(5,104 Views)
Hi anyang,
Can you provide some additional details to give us the context of your system?
  • Where did you obtain this program?
    • If it is a program you built yourself, please provide some additional details regarding how you are running it:
      • Are you running it on a development machine with a full version of LabWindows/CVI?
        • Which versions of LabWindows/CVi do you have installed?
        • Which controls are you using on your GUI?
      • Are you running it on a deployment machine?
        • Did you install this program using a LabWindows/CVI-built installer, or did you copy the executable file to the target?
          • If you created an installer, with which options did you configure your installer?
      • What version of the mesa.dll file is present on the system in which you are trying to run this program?
We appreciate any system detail you can provide so we can better help you with this issue.
Warm Regards,
Daniel Dorroh
(5,040 Views)
