LabWindows/CVI
mesa.dll not found
I installed Labwindows/cvi 8.1 on an XP computer.
After installing everything including the drivers I reboot the PC and then attempt to launch Labwindows. I get a error popup saying cannot find mesa.dll. I have to ctrl-alt-dlt and stop the task thru the task manager, only way to get out of this. I did a search for mesa.dll on the computer and it is in several folders.
What do I need to do to get going using Labwindows on this computer? Never had a problem on any of the other computers I have loaded Labwindows on.
Thanks!
John W.
(7,344 Views)
Accepted by topic author jwinterb
It appears that the issue might be the VS 2008 C++ runtime package as discussed in this thread.
You can try downloading the installer and installing separately (link is in the last post of the above thread).
Evan See
(7,326 Views)
Thanks.
I ended up deleting the National Instruments folder residing in Program folders. Then uninstalled NI and then reinstalled. Does not flag this error anymore.
(7,312 Views)
