LabWindows/CVI
messagepopup text size
I was wondering if ther was a way in increase the font size of the text in the MessagePopup() window?
(4,423 Views)
You'll find some suggestion in this discussion
(4,418 Views)
So The only way I can controll the text size for a popup is to use panels and not the built in MessagePopup correct?
(4,410 Views)
Building your own panel gives you the ability to define in detail the aspect of each particular message of yours, even movin far apart from windows standards; changing system attributes maintains the look and feel of the OS which can be important for the operator (he does not need to become familiar with some "new" messages and popup).
It's to you to decide wether to follow one path or the other.
(4,407 Views)
Hello Jim_81,
In order to change the font and size of the text associated with MessagePopup, you can add the following keys (this applies to CVI 7.1)*:
MessageBoxFontName
MessageBoxFontSize
to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\CVI Run-Time Engine\cvirte
The keys need to be of type STRING.
For instance, if you wanted to change the font of the messagebox to Garamond and size 20, your registry would look something like:
*As with anything, I would be careful when making changes to your registry.
Thanks.
Message Edited by Wendy L on 06-15-2005 02:02 PM
Wendy L
LabWindows/CVI Developer Newsletter
(4,382 Views)
