LabWindows/CVI
minimizable exe uses low resolution icon instead of high resolution icon
I am using LabVIEW 2009 (pre-SP1) on a Windows 7 platform.  If I build a .vi into an application and use a custom icon or even the default LabVIEW icon and make the top-level vi minimizable the low resolution icon (16x16) is used in the taskbar instead of the high resolution icon (256x256).  However, if the top-level vi is set to not-minimizable then the high resolution (256x256) icon is used in the taskbar (see attached).  This would not be prevelent in pre-Vista platforms because only the low-resolution icon is available to applications in the taskbar.  Anyone else encounter this?  I think this is a LabVIEW 2009 bug but haven't tried it with SP1 yet.
Steffan
(3,273 Views)
Hi sbenamou, you have erroneously posted your question to the LabWindows/CVI board: you should post it in the LabVIEW board instead.
(3,261 Views)
opps, my mistake!  Will do.
(3,248 Views)
