LabWindows/CVI
modbus communication in CVI
I have an assignment of developing a module that can make the application communicate with a Device Controller, using the MODBUS protocol.
I have tried the sample code available with the NI LabWindows/CVI/Sample.prj. But I have been unable to read back anything from the controller.
Can someone suggest me some basics for this problem. How should I code the program so that it reads back from the Device.
Any suggestions or sample codes would be helpful.
Dwivedi
(3,482 Views)
How are you communicating with the device? Is it serially? Do you have the correct driver installed for the device that you are trying to communicate with? Here is a link that may help.
Here is another >link that may help in troubleshooting your communication problem. Although it deals with LabVIEW, the same ideas apply to CVI.
Russell G.
NI Applications Engineer
(3,482 Views)
