LabWindows/CVI
mouse over menu bar stops program execution
I am using a menu, and get the same problem as in this discussion board: Every time I move my mouse over a menu in my Labview (7.1) application, my program halts . I simply use the vi 'Get Menu selection' (Application control -> Menu -> Get Menu Selection) and get the same problem as discussed here. Even if I use an Event structure, I get the same problem.
After reading your solution, I'm afraid I still don't understand your practial solution to the problem. Could you clarify maybe with a small example VI (I am using Labview 7.1)
Many Thanks!
Thijs
Message 11 of 14
(1,567 Views)
You should repost your query on the LABVIEW forum; this thread was discussing a LABWINDOWS/CVI problem.
JR
Message 12 of 14
(1,559 Views)
Thijs:
Are you just trying to obtain the current user selection from the front panel? Please let me know.
Rudi N.
Message 13 of 14
(1,517 Views)
I posted the question on the labview forom, and manged to solve the problem later on by using a small timeout value in an event loop.
Thanks!
Thjis
Message 14 of 14
(1,508 Views)
