LabWindows/CVI
move graph cursor with mouse
Hi Jason,
After further investigation into the plot area offset issue, I found that GetGraphCoordsFromPoint() requires panel coordinates and not coordinates with respect to the graph control. With this in mind, the following modified code should work:
int CVICALLBACK GraphCallback (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
    int xCoordinate, yCoordinate, leftButtonDown, rightButtonDown, keyModifiers;
    double xCursor, yCursor;
    switch (event)
        case EVENT_MOUSE_MOVE:
            GetRelativeMouseState (panelHandle, 0,
                &xCoordinate, &yCoordinate,
                &leftButtonDown, &rightButtonDown,
                &keyModifiers);
            if (GetGraphCoordsFromPoint (panelHandle, PANEL_GRAPH,
                    MakePoint (xCoordinate , yCoordinate),
                    &xCursor, &yCursor))
                SetGraphCursor (panelHandle, PANEL_GRAPH, 1, xCursor, yCursor);
        break;
    return 0;
Message 11 of 12
(1,159 Views)
That does put the cursor on the exact pixel position. I tried finding a simple CVI function which would find the data of the plot at that pixel x,y position.
This is how I solved it (the long way):
Basically I took the width of the graph. Then I got the x,y position with the extendedmouseevents. Then I used that as a percentage and used it for the index of the plot.
So if there are 100 elements (0-99 index) and the position is 10% of the graph ( mouse position x / width of graph = .10) then the index is 9. THEN I plot the cursor to index 9 of the plot and attach it there. Then I get the value of the x,y graph and show it in a text box.
I feel a function to convert pixel position to the axis data would be easiest and what I did does basically that. Problem solved (sorta)
Thanks all for ur help in letting me understand this better and settle on this option.
Message 12 of 12
(1,144 Views)
