LabWindows/CVI
mplab ActiveX controler
I have a plan for an automatic testert. I have to program a card-based PIC microcontrollerusing MPLAB IDE. I am willing to make the task automatically. I want to know if there is an ActiveX controler (such as Excel, IE ...) or something else to controlMPLAB.
Thank you
(3,345 Views)
Hi Fishingman,
Could you provide some more clarification on how CVI will be used? Is it going to be controlling MPLAD? What do you mean by you are willing to make the task autamatically? Please explain.
Perry S.
(3,336 Views)
Thanks for your reply,
I work with LabWindows / CVI 2010. The idea is that I run a program that will take the role Labwindows order MPLAB and program the microcontroller of the card. So what I want, is to order options MPLAB (as we do with IE, Excel, ...).
Cordially
(3,328 Views)
Hi Fishingman,
We do not provide the activex controls for other software. We do however provide a wizard that allows you to create the library of controls for any software that has that option. To check if you can make the library go to Tools >> Create activex controller >> Next. If your software is listed in there that means that you can create your controls. Here are a few tutorials and help files that explain a little more.
http://digital.ni.com/public.nsf/allkb/4B597F188B89B6DD862568970071F2FC
http://zone.ni.com/devzone/cda/tut/p/id/4978
http://zone.ni.com/reference/en-XX/help/370051T-01/cvi/usermanual/prjcreateactivexcontroller/
I hope that these help.
Perry S.
(3,316 Views)
