LabWindows/CVI
multiple c files
Hopefully I can phrase this with out too much confusion!!
Can I do the following and if so how?
I have two projects in CVI and I would like to put them into one as the functionally and UIR’s in both I need to use.
The two were developed at different times but I now need to rolled both into one application.
Each project has a single UIR and a single c file.
Project 1 is the main project, which will be calling, via a command button (I hope), project 2.
This, as you can see, is a new departure for me as I normally write one big c file doing all the work and I have never ventured into multiple c files with just one master!!!
Thanks for the help
Simon
Still learning!!
(3,276 Views)
CVI can manage projects that include several source files as well as several UIR and include files: the Edit >> Project menu item can help you in adding all the files you want.
Some hints on managing such projects:
  • You must have only one main () function in the project
  • Similarly, it's better that you call RunUserInterface only once
  • Every source file must include the necessary files to run (toolbox, analysis, instruments...) and the include file(s) of the UIR(s) that the module needs to operate on
  • Global variables and function definitions other than those associated to UIR controls can be defined in a separate include file to #include in every source file
This means that merging two projects should not be a complicated matter: you must decide which is the master application and call the "slave" from this one; in the called app the main routine is replaced from the calling routine from the master app; next you will need to handle the interactions between the two projects merged, if any.
(3,267 Views)
