LabWindows/CVI
multiple channel output
Hello
I need to acquire two external siganls and output them in individual graphs using DAQmx. I used decimate array function and connected waveform graph function for each output of decimate array. Is that the right way to output individual signals? Can somebody help?
(3,213 Views)
Your vi seems a good approach to me. Anyway, in case you have some problems I suggest you to post this question to the LabVIEW forum: this one is dedicated to CVI and you will find more rapid and specialized support in that board Smiley Wink
(3,187 Views)
