LabWindows/CVI
multithreading in CVI
I am trying to learn the multithreading issues in CVI. I am looking at the
supplied examples and 1 application note that I found on the NI web site
(called Multithreading in LabWindows CVI). After going though these and
online help, I am somewhat confused. Is there some detailed document guide
or something in regards to using multi-threading in CVI? I can't find one.
(3,173 Views)
Yes. Look in your cvi\bin directory and you will find a document called MultithreadingOverview.pdf. It has all the info you should need on multithreaded programming in CVI.
Best Regards,
Chris Matthews
(3,173 Views)
