LabWindows/CVI
mysql authentication error
I am using sqltoolkit. It works very good on remote, but I have a problem when I try to work on my PC ( localhost )
I am  using Mysql server 5.0 , and when I try to connect I got this message:
"Client does not support authentication protocol requested by server;consider upgrading MySql client"
I am using this parameters to connect SQL:
    #define SQL_SERVER "localhost"
    #define SQL_USER   "username"
    #define SQL_PASSWORD "mypassword"
    #define SQL_DBNAME "dbname"
Do you have any idea?
Daniele
Message 1 of 9
(5,623 Views)
Hi Daniele,
you stated that your program run on remote: what exactly do you mean? Which parameters did you use on the remote PC?
Are you able to run CVI examples and correctly connect to a database?
What did you install on the different PCs?
Bye,
Licia
Message 2 of 9
(5,599 Views)
Ciao Licia,
With remote I mean that my application is able to connect to mysql database on remote server, but when I try to connect with  Mysql server on  my PC doen't work and I got the message error wrote above. MySQL server (version 5.0) work correct with other application (i.e. Web application ) but not with my CVI app.
Ciao
Daniele
Message 3 of 9
(5,594 Views)
Ciao Daniele,
MySql server is the same?
Licia
Message 4 of 9
(5,591 Views)
Yes Licia, Mysql server for both systems.
Thanks Daniele
Message 5 of 9
(5,589 Views)
I'm sorry, I meant the version...
Bye!
Licia
Message 6 of 9
(5,587 Views)
MySQL server 5.0 on both system I mean.
I am sorry for my  imprecision
Daniele
Message 7 of 9
(5,585 Views)
     Are you able to connect up to it using the MySQL Browser?  If you use a Web application it is going through the Apache server, not directly to the MySQL daemon.  Are you using the MySQL API or NI SQL Tool Kit?
Mike
Message 8 of 9
(5,562 Views)
Hi Mike,
I don't use API, but NI SQL Tool Kit.
For my web application I use Apache and PHP and work without problem on localhost.
When I set in my CVI app the parameter for MYSQL connection on LOCALHOST I received the error wrote above...
Daniele
Message 9 of 9
(5,557 Views)
