LabWindows/CVI
namespace syntax error
I wonder if Labwindows support namespace. I find that it doesn't seem to be the keyword in labwindows.
I have a .h file, just like the following style:
namespace CL_DEF
however, when compile such .h header, there seems to be syntax error about the statement:
syntax error, found 'identifier' expect ';'
I wonder who can help me out. Thanks a lot.
(3,935 Views)
Namespace is a C++ notation and  Lab Windows CVI uses a C compiler, it would be like trying to use classes in C.  If you want to group information I suggest using structs.
Garth
(3,929 Views)
Thanks a lot for your quick answer. You really help me a lot.
(3,906 Views)
