LabWindows/CVI
.net - IDictionary
I need to create a dictionary of type "System_Collections_Generic_IDictionary_T2" using labwindows CVI.
Can anyone send me a sample code ?
Regards
srk
(5,500 Views)
Hi srk,
Are you currently working with a .NET controller in LabWindows/CVI? Can you give more context for your question?
Daniel Dorroh
(5,484 Views)
ello Dan,
I created a .net controller in labwindows CVI for dSPACE.HILAPI.MAPort.dll, which generated a .fp/.c/.h that has below function.
int CVIFUNC ASAM_HILAPI_dSPACE_MAPort_MAPort__Create(ASAM_HILAPI_dSPACE_MAPort_MAPort * __instance, System_Collections_Generic_IDictionary_T2 configurationDict, CDotNetHandle * __exception);
I am looking for help in creating dictionary of type 'System_Collections_Generic_IDictionary_T2'.
I did not find any functions in mscorlib/mscorlib2 which can create a dictionary of type 'System_Collections_Generic_IDictionary_T2'.
(5,469 Views)
Hi srk,
I would expect that type to be present in the function panel for your .NET controller. Do you not see it there? If you try to browse for the type definition of System_Collections_Generic_IDictionary_T2 in your LabWindows/CVI project, does it find anything?
Daniel Dorroh
(5,459 Views)
Hello Dan,
Definition is pressent in mscorlib.h
typedef struct __System_Collections_Generic_IDictionary_T2 * System_Collections_Generic_IDictionary_T2;
(5,448 Views)
