LabWindows/CVI
.net assembly event handler in labwindows using the .net library
Has anyone got any information on using an event handler from a .net assembly when used through the labwindows .net library?
(3,215 Views)
Current versions of CVI do not support subscribing to .NET events.
(3,204 Views)
As Mohan says, we don't currently support it directly, however there's a sort of implementation option if you can use the .Net assembly as your Main program, and call into your CVI code as a DLL :
http://digital.ni.com/public.nsf/websearch/346E949235C54BA086257234005607E0?OpenDocument
Not necessarily practical if you don't have access to the source code though.
Sorry
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,184 Views)
