LabWindows/CVI
newbie to programming for the pci6111e card
Hi there, i was asked to create a c or c++ program that will record X and Y pulses that come in simultaneously. Can someone give me a clue on where to start?
Thank you
(2,864 Views)
Greetings,
The NI Development Library has hundreds of examples that will get you started with your application. Additionally, when you install the NI-DAQ driver and select that you want Visual C/C++ support, examples will be placed on your hard drive. Look in \Program Files\National Instruments\NI-DAQ\Examples\Visual C. If you don't see this directory then you will have to re-run the installer for the NI-DAQ driver and add these examples.
I assume that X and Y are analog signals that you want to acquire simultaneously. Look in the "ai" directory for examples on analog input.
Development Library
http://zone.ni.com/devzone/devzone.nsf/6ae7945502d89dea0625685500506e1f/4d58b1b80ec41ef70625683f006e1d6d?OpenDocument
Justin Britten
(2,864 Views)
