LabWindows/CVI
newport driver
Dear friends,
I have some problems to init Newport 2832-C Dual_Channel Power Meter:
Newport GPIB has no doc show the sequence of data collection. Buffer has two or three previous data value to show the new data even I did:
LOOP:
Start new data value
"STOP_A"  stop channel acq
"DSCLR_A"  Data Store clear
"RUN_A"    Start ch data acq
"R_A?"     Read ch meas quary
LOOP_END
It does not help even I change the buffer size to 1 from default 100.
If you know how to clear those buffer, you are the big helper to me!
JD
(3,188 Views)
Hi JD,
You posted in the CVI forum, so I assume you are not using LabVIEW. I didn't see a CVI driver on our instrument driver network, but I looked at the LabVIEW driver that was available. It is not officially supported by National Instruments, but searching through the VIs, it looks like the driver sends a "DevClear" command to "empt[y] the 2832-C's GPIB output queue and clear the MAV bit". I'd give this a shot and see if it works for you. Thanks!
Ebele O.
(3,122 Views)
