LabWindows/CVI
ni daq reading voltage display on a panel meter
I am looking to display the reading from a DAQ (possible 6009) on a meter, something like a voltmeter.
I thought there was something available, but I am not able to find anything.
I'd like something that would be modifiable (if possible) to show something to indicate the minimum and maximum values read, and to continuously display the values read, at perhaps ever 100ms.
(3,166 Views)
Hi;
With the meter controls and the DAQ tasks that you can program in CVI you can achieve what you explained, I attach a little example that includes the DAQ task to acquire Voltage and the part to display the value to a meter.
Hope the information is useful.
Good Luck
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
(3,130 Views)
Thanks Francisco.
That was what I was looking for.
I thought there were some meters like what you attached already built somewhere (on the NI site or with the DAQ drivers or something). But, this is a quick start for what I'll need to create.
Thanks again.
Ken
(3,128 Views)
