LabWindows/CVI
niSync_GetTime's last parameter timeFractionalNanoseconds
In the NISync API Reference, the last parameter for niSync_GetTime is
timeFractionalNanoseconds ViUInt16* An output integer that specifies a portion of the board time.
Since this is an integer, what is the implied denominator?  For example, is it X / 100 nanoseconds?
Thanks!
YeeMan
(3,487 Views)
I took a look at the LabVIEW subvi for the time conversions and discovered this number is 1G ( 1,000,000,000)
See the attached image.
Christian A
(3,438 Views)
Thank you Christian.
Your attached image helped confirm my time conversion function.  I also ignored the fractionalNanoseconds.  Given that the resolution of the clock was 16 ns, I was confused by this fractionalNanoseconds parameter.
(3,433 Views)
