LabWindows/CVI
nidaqmx not found
Hi:
I'm having problems with NIDAQmx.h
This is the sequence of what I've done so far:
- Install Windows 7 Professional
- Install CVI 10
- Install NI-DAQmx 15
- Plug the card (NI USB 6218)
When I try to run a project I've run in other computer (with same configuration, except NIDAQmx is 14.5.1) I get a pop-up "The include file NIDAQmx.h was not found. Do you want to look for it?"
I've pointed CVI to c:\Program Files <x86>\National Instruments\NI-DAQmx Base\Include\NIDAQmxBase.h and then I get  the "Missing Prototype (Require function prototype build option is enabled.) warning....
What I've done wrong?
How can I fix it?
Jose
(4,343 Views)
DAQmx Base is not even close to being the same as DAQmx. You've installed the wrong driver. Uninstall the Base driver and install the correct DAQmx. The base is intended primarily for other os's.
(4,334 Views)
Ups!
And the latest version is 15.1.1? http://www.ni.com/download/ni-daqmx-15.1.1/5665/en/
Not to make same mistake again.
(4,319 Views)
