LabWindows/CVI
nidevmon.exe- component not found
Hello
After installing DAQ software (8.9.5), connecting my DAQ hardware (NI usb 65-01) and restarting my computer, I receive Error nidevmon.exe,
and I had this following sentence:
In French:
"Cette application n'a pas pu démarrer car nimru2u.dll est introuvable. La réinstallation de cette application peut corriger ce problème."
"This application couldn't start because nimru2u.dll couldn't be found. Réinstall this application can fix this issue"
I try to fix that with this following link:
http://digital.ni.com/public.nsf/allkb/6F520C54419C655F862572C0007B462B
What can I do, please?
thank you
Dayn
(3,412 Views)
Hello Dayn,
The nimru2u.dll is associated with our DAQmx driver and should have been installed into the <System32> directory. My guess is that you won't find this DLL in your <System32> directory. Thus what I recommend is to install DAQmx 9.0 onto your system found here
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,384 Views)
