Hello Erwin
This is possible. After the malloc, right click on the variable and select "View Variable Value" during debugging. You should be able to view the individual array elements.
CVI includes the CVIDynamicMemoryInfo() function to allow you to view the total dynamic memory allocated in your application. You can get multiple snapshots to track the state of your dynamic memory
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
