LabWindows/CVI
no thumbnail preview on taskbar for CVI when debug process is executed
I am wondering why there is no thumbnail preview on the Windows taskbar for CVI when its debugged process is being executed.
I am attaching two screenshots for Win7 and CVI2015.
1) no process being debugged: t.png
2) the project is running: t2.png
(4,129 Views)
Hi Wolfgang,
I tried to reproduce the behavior on my system, but I do not see the behavior. Attached, you can find a screenshot, of what I see.
Do you see this behavior on multiple machines?
Do you have a customized Windows installation?
Does the thumbnail preview appear after waiting  while? Sometimes Windows needs some time to load the preview.
Do you do something special, that I can do to reproduce the behavior?
Melanie Eisfeld
Staff Applications Engineer
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(4,111 Views)
Hi Melanie,
Thanks for looking into it! I tried the same project as you and got the same result as you - as long as the Environment setting 'Hide windows when application is running' is not set.
You can reproduce my observation when checking this setting. The debugger will hide/minimize its window, leaving only the taskbar icon as is standard Windows behaviour. But unlike other Windows programs it will not show a thumbnail...
(4,105 Views)
Hi Wolfgang,
thank you for the hint.
I see the same behavior as you described in the original post when activating "Hide windows when application is running".
I am not sure, if this is a CVI issue or a Windows one. I wiil take a deeper look into that and let yo know about the results.
Melanie
Melanie Eisfeld
(4,094 Views)
Hi Wolfgang,
after looking into this issue, I reported it to R&D. The tracking number is 595223. Thank you for reporting this issue to us.
Melanie
Melanie Eisfeld
(4,083 Views)
Thank you Melanie!
Would you mind having a look also into this?
(4,080 Views)
