Hi Chocomoos,
When using SetCtrlVal() on the controls that are on the Tab Pages you'll want to pass the handle to the Tab Panel.
So I added to the top of your munsu.c:
int TabPanelHandle1;
int TabPanelHandle2;
Then in your Initialize_DataView() function I added:
GetPanelHandleFromTabPage (PanelHandle, PANEL_TAB, 0, &TabPanelHandle1);
GetPanelHandleFromTabPage (PanelHandle, PANEL_TAB, 1, &TabPanelHandle2);
and I changed your SetCtrlVal() functions to pass in the TabPanelHandle1 or 2 depending on which tab page the control is on. So it would look like:
SetCtrlVal(TabPanelHandle1, TabPanel_1_Chk_D1_830_Ch9, status.Chk_D1_830_Ch9);
Then, you'll also need to fix it in the rest of your code.
Let me know if you have any questions.
Kristen
