LabWindows/CVI
objects move whne saved
I have objects on a panel that are shifting position (up or down) when the panel is saved...   this started just after I added a drop down menu to the panel.  Here's the before and after snapshots..  the before is just after I have moved all the objects to the correct position (select all objects and move them into place with the arrow keys or with the mouse).  The "after" is an example of what I see just after saving the panel...  upon save, the objects either all move down (as in the example photo) or they all move up (the top control button landing half-way under the menu bar) ...    I actually see the objects moving as the the save is happening ....
Strange...  Smiley Mad
Anyone with a suggestion?
JUST BEFORE SAVE AND AFTER MOVING OBJECTS TO DESIRED LOCATION
AFTER SAVE !!
(3,726 Views)
This bug (Objects on GUI Panel move when it is saved) was confirmed by NI Support ..  Here's the e-mail record for anyone who might have this same problem....
Cheers.
-------- Original Message --------
Subject: Re: (Reference#7199315) Bug Report: Objects on Panel Move when the panel is saved
Date: Fri, 13 Jun 2008 10:19:35 -0500
Reply-To: support@ni.com
Following your instructions, I was indeed able to replicate the problem.
Note that this occurs in CVI 8.1 and 8.5.1.
I will file a corrective action request to inform CVI R&D of the behavior.
I will then inform you of what R&D has to say about the issue.
Do pardon the inconvenience. Let me know the severity of the problem so
that I may address the issue accordingly.
Have a great and safe weekend.
Nestor Gomez
http://www.ni.com/support
Here is the process I used ....
open the TT_00_UI.uir file ...
Select ALL the objects with the mouse....
Move them up or down using the arrow key ...
On the left of the screen is the project explorer list ...  right click
over the TT_00_UI.uir file ... you should get a pop up menu list.
Left click on "Save"
The objects should now move on the screen to some other position ....
however...  if they don't move, then
close the TT_00_UI.uir file so that you can't see it anymore, then go back
and open it and the objects should be in another position ....
Let me know if you can get this duplicated. Thanks for your continued help.
(3,688 Views)
This was reported to R&D (CAR ID # 116077) for further investigation.
R&D is currently investigating this issue. Do pardon the inconvenience Dan.
Message Edited by Nestor_G on 06-15-2008 11:35 PM
Nestor
(3,668 Views)
CVI R&D is further investigating this bug.
However, a workaround to the problem is to simply not choose the Sample Menu Bar, but rather the actual or a dummy menu bar.
Pardon the inconvenience everyone.
Nestor
(3,597 Views)
