LabWindows/CVI
obtaining resource base address
I am using NI's 8 port RS232 card and I'm programmatically obtaining the port numbers and names for each COM port. However for my application I must use the low level functions to change the baud rate on the fly. Is there a way I can find the base addresses for each of the ports or even for the card as a whole.
I am trying to avoid look-up tables as the software ideally needs to be platform independent.
Your help is much appreciated!!
Alan
(3,272 Views)
Look up and enumerate the com ports in the system registry. There is enemeration functions and registry tools in the programmers toolbox.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,250 Views)
