LabWindows/CVI
one of the data saved incorrectly in a file
After setting manual panel with data and saving it to a file, it turned out that one of the data was incorrect (garbage). Please advice what can cause this. We use Labwindow/cvi 6.0 on a win2000 pc.
(4,259 Views)
How are you saving the data to a file? are you using SavePanelState? or do you use your own binary format?
Make sure that you delete the content of the file before writing noe data to it; it's possible that there are some leftovers in the files that curropted the data.
Please post more details on this so we can help you better.
Juan Carlos
N.I.
(4,259 Views)
The code is not mine and i don't have more details. Anyway the project team solved the problem (an old corrupted file was used by mistake). Anyway, thanks a lot for your response.
(4,259 Views)
I'm glad this was fixed.
Let us know if you have any further questions.
Juan Carlos
(4,259 Views)
Sure. Thanks again.
(4,259 Views)
I just go through with getting started and i have problem in labwindows ,  i want to read data from the file  but i dont know how to do it .
what actually the syntax of  fscanf  function.
(3,953 Views)
fscanf
int fscanf (FILE *stream, const char formatString[], ...);
for instance
    fscanf( Input_File, "%i", &Ticks_Interval );
(3,927 Views)
