LabWindows/CVI
only directory selection file selection shouldn't be allowed
Need Directory selection popup....
file selection shouldnt be allowed..
(2,859 Views)
when using DirSelectPopup, files are visible and can be selected by the user. The function will only return a directory, but I totally agree with you that this is very confusing for the user. There should be an option to hide the files for the user.
A possible solution to your problem is creating a Directory Selection Popup panel yourself, using a File Browser control (Custom Controls -> Toolslib Controls -> File Browser). This is actually a tree control, converted into a File Browser. The File Browser function panel is located here: C:\Program Files\National Instruments\CVI80\toolslib\custctrl. Note that the CVI80 directory name is different for each CVI version. In this function panel you will find the FileBrowser_Create function, which transforms the Tree control into the file browser. Now you can use the FileBrowser_SetAttribute function to change the File Browser's attributes. This way you can enable the 'Browse Directories Only' option.
A disadvantage of using this file browser is that it doesn't look very need, and you have to program the whole thing yourself.
Good luck,
Wim
(2,858 Views)
