LabWindows/CVI
opal kelly XEM3005 and LabWindoes/CVI 8.5
I'm using LabWindows/CVI v 8.5
I have created the worlds 2nd simplest GUI, a quit button, a switch, and an LED that reflects the status of the switch.  This works fine.
When I include the okFrontPanelDLL.h file (and that's all), the thing refuses to compile.  It appears to be choking on a "bool"
I have had the GUI creater create a winmain, and I have gone into my options and made sure the settings are VisualC++.
Any clues?  I can include code and projects if necessary.
(3,196 Views)
CVI means C, not C++
(3,190 Views)
*THAT* is really unhelpful...
(3,166 Views)
That's sad to read. It should have told you that CVI is choking on your bools because bool is not C, but C++.  Fortunately it seems that you have solved your problem now.
(3,158 Views)
