LabWindows/CVI
opal kelly constructors and LabWindows/CVI
Hello, all.
I am trying to get an Opal Kelly XEM3005 board up and running with LabWindows/CVI 8.5.
I have been in touch with OK's Tech Suppt, and have run down the initial issues of "bool" types.  After having (at OK's recommendation) with "char" types, I can now include the headers without errors.
There is, however, a new problem:
When I call the constructor function, which should return a pointer to an "okFrontPanel_HANDLE" type, I am getting an error for a missing prototype for the constructor(s).
Dredging through the .c(pp)  file, I found the following:
// Function calls - okCFrontPanel
okDLLEXPORT okFrontPanel_HANDLE DLL_ENTRY
okFrontPanel_Construct()
    if (_okFrontPanel_Construct)
        return((*_okFrontPanel_Construct)());
    return(NULL);
However, trying to call it just gives me a "missing prototype" error.
Of course, doing some more dredging turned this up in the ".h" file:
// okFrontPanel
okDLLEXPORT okFrontPanel_HANDLE DLL_ENTRY okFrontPanel_Construct();
okDLLEXPORT void DLL_ENTRY okFrontPanel_Destruct(okFrontPanel_HANDLE hnd);
So I'm not sure I understand what's going on...  What is the horribly simple (and obvious) thing I am missing?
Relevent code snippets included below:
try1.c:
#include <cvirte.h>
#include <userint.h>
#include "Try1.h"
#include "XEM.h"
#include <windows.h>
//#define _WIN32
static int panelHandle;
static okFrontPanel_HANDLE    XEM_Device;
int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
                       LPSTR lpszCmdLine, int nCmdShow)
    if (InitCVIRTE (hInstance, 0, 0) == 0)
        return -1;    /* out of memory */
    if ((panelHandle = LoadPanel (0, "Try1.uir", PANEL)) < 0)
        return -1;
    DisplayPanel (panelHandle);
    RunUserInterface ();
    DiscardPanel (panelHandle);
    return 0;
int CVICALLBACK Connect (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
    int    Value = 0;
    switch (event)
        case EVENT_COMMIT:
            GetCtrlVal(PANEL, PANEL_CONNECT_SWITCH, &Value);
            SetCtrlVal(PANEL, PANEL_CONNECT_LED, Value);
            if( Value )
                XEM_Connect(XEM_Device);
            else
                XEM_Disconnect(XEM_Device);
            break;
    return 0;
int CVICALLBACK Quit (int panel, int control, int event,
    switch (event)
        case EVENT_COMMIT:
            QuitUserInterface (0);
            break;
    return 0;
XEM.c:
int XEM_Connect ( okFrontPanel_HANDLE    XEM_Device )
    int    NoDevices = 0;    //    Number of devices attached to the PC
    //    Load the DLL (?)
    // Load the FrontPanel DLL
    if (FALSE == okFrontPanelDLL_LoadLib(NULL))
        printf("Could not load FrontPanel DLL\n");
        exit(-1);
    //    Find out how many devices are attached
//    XEM_Device = okFrontPanel_Construct();
    XEM_Device = okCFrontPanel();
//    NoDevices = okCFrontPanel();
    printf("%d OK devices attached\n", NoDevices);
    //    Call the contructor?
//    okCFrontPanel ();
    return XEM_SUCCESS;
int XEM_Disconnect ( okFrontPanel_HANDLE    XEM_Device )
    //    Call the Destructor (?)
//    ~okCFrontPanel ();
    return XEM_SUCCESS;
(4,053 Views)
Accepted by topic author tomii
Hi tomii,
It looks like you posted another very similar thread about compiling errors with your Opal Kelly dll's here. I will be following up in that thread to help get some traction with these issues.
James W.
(4,028 Views)
Well, I started this new one to give more info, as things have progressed some, and the answers I was getting in the other were not especially helpful.
Right now I'm at a linking problem (I think)
(4,025 Views)
Let me rephrase.  Yes, there is a new thread with much more recent info in it.  Sorry for the confusion
(4,023 Views)
