LabWindows/CVI
open a file with a particular application in CVI
I have a notepad file with x and y data's and i want to open it with a plotting app. I used system("notepad xy.txt") function to open it with notepad and had no issues but by using system("plotapp xy.txt")  wasn't working. Is there a way to do this differnetly?
(3,332 Views)
Might it be that you need to use "\full\path\to\plottapp.exe" instead of just "plotapp" ?
(3,310 Views)
... or the full pathname to the data file.
Does system () return any error?
(3,302 Views)
yes , But i have managed to work the application by Using CopyFile() to copy plotapp to a the folder which  the text file lies. I ve  also tried giving path name in System but doesnt work . System() works pretty fine for System 32 prgrams
(3,286 Views)
I ve tried it but doesnt work
(3,285 Views)
I used CopyFile to cply the app and used system()  and setDir to open it from there and it works . Thanks all for help.Smiley Happy
(3,207 Views)
