06-01-2016 08:57 AM
I made the following observation:
I have a file compiling fine; now I add the line
open ( file_name );
to one of my functions ( file_name is defined) and compile again. I receive the message that I need to add the above mentioned include statement. By the way, I already have this include statement... I don't mind, press 'Yes' and CVI adds this line to my code. Then I compile again and I receive exactly the same message... I can continue piling up these include lines without effect, so I would tend to assume that something is wrong here ![]()
Solved! Go to Solution.
06-02-2016 02:41 AM
Hello Wolfgang.
This is the same as this one: http://forums.ni.com/t5/LabWindows-CVI/can-t-find-ansi-c-h-library/m-p/3030109#M68535
In the mean time Include file was updated in the help but the detection of the include file cannot be fixed because it's based on the library name.
Constantin
06-02-2016 03:10 AM
Thanks!
