LabWindows/CVI
open web browser from labwindows CVI
Hello!
I am looking for some function or utility through which I can open the web browser from CVI. Also if I have a choice of the webpage, that will be great!
Thanks.
Madan
(5,163 Views)
There is a function "ShellExecute" in the SDK that does the trick.
In the callback for a button, for whatever control you are using to initiate launch of the browser, put in this function call:
ShellExecute(0, "open", "www.yourdomain.com",NULL,NULL, 3);
Those parameters work for me, but I can't explain them all from memory. For details, see the SDK help.
--Ian
(5,163 Views)
The best way to do it is with ActiveX. Check out this example program:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DD4156A4E034080020E74861&p_node=DZ52156&p_source=External
I think there also may be one that ships with CVI at
[CVIDIR]\samples\activex\ie. Where [CVIDIR] is the directory CVI is installed to.
Ryan K.
(5,163 Views)
Thank you. I got this thing working.
-tmach
(5,163 Views)
Can you share your Code? Did it work with ActiveX or ShellExecute from SDK?
(3,601 Views)
