LabWindows/CVI
opening a file in wordpad from CVI
I am using CVI to create a data file called abc.txt.
I would like to have a CVI button that would open this file in wordpad.
Any ideas?
(2,945 Views)
Try:
LaunchExecutable("wordpad abc.txt");
or
system("wordpad abc.txt");
Also the entry by JoeTestEngineer at the end of this thread
http://forums.ni.com/ni/board/message?board.id=180&message.id=23545&requireLogin=False
will help if you run into timing issues.
Good Luck
Message Edited by mvr on 06-21-2006 02:23 PM
(2,939 Views)
