LabWindows/CVI
orcad wirelist
I know this may be a little far fetched, but does anyone know if it is possible to generate a wirelist.dll file for orcad using either CVI or Labview. The install directory for Orcad has a way of doing this is vb, but their example does not compile the the newest visual studio software.
(4,544 Views)
Hello Steve,
I am not sure that there is any direct, straightforward means of creating the aforementioned dll in LabWindows/CVI.  However, one thing does come to mind:  Orcad can interact with an NI product called Multisim.  Multisim can interface with NI's LabVIEW.  LabVIEW can then interface with LabWindows/CVI.  This is a long line of dependecies, but it may afford you some degree of interaction between Orcad and LabWindows/CVI in the end.  I don't know if it will specifically allow you to create the wirelist.dll file you mentioned, but it may provide you a starting point as you further investigate your end goal.
(4,514 Views)
Considering that no sufficient answer was posted, I'll repost the question. Orcad contains a feature to generate a wirelist from the schematic. It contains a microsoft template for generating the DLL, but I would like to generate the DLL using Labwindows or Labview. Would anyone know how to generate the DLL in one of these environments?
(4,214 Views)
Hi Steve,
Unfortunately, I'm not familiar with Orcad.  Please explain in a bit more detail what Orcad does when it generates the DLL.  Does it provide you with a header file and a source file that you can use to build a DLL?  Or is the template something that VisualStudio recognizes and uses to build a DLL?
(4,164 Views)
