LabWindows/CVI
oscilloscope reading after falling edge with some delay
Hi All,
I am trying to measure some voltage level after the falling edge with some delay. For example, The falling edge (with some criteria, say cross 2.5V) happens at t1 and I would like to measure the voltage at t2=t1+100us. The t1 is changing, but 100us is fixed.
How can I do this with labview automatically?
Thanks.
Andrew
(2,851 Views)
Hi Andrew,
the LabVIEW forum can be found here; there you most probably will find better support for your question; the forum here is dedicated to LabWindows/CVI...
Good luck!
(2,846 Views)
