LabWindows/CVI
out of bound indicator controls
Hi
I need a control which indicate the value range need to within 2 ~ 5V for example. I need
one (or two) controls to indicate it either out of upper bound or low bound, which controls
shall I use? (And I don't need display the real value is, only knows it's OK or fault(out of bound)).
(I'm using CVI 2015).
(5,446 Views)
I am not sure that I correctly understood your problem, but did you consider setting the control, e.g. a numeric control, to 'Range Checking = Notify'?
(5,441 Views)
I need show the voltage is either out of upper/low bound or normal, like a warning light.
(5,438 Views)
This is what this setting does - if the value is inside the minimum/maximum values, it is just a normal control, if the value is outside of the specified range, an 'out-of-range' box appears.
Another possibility is adding two LED controls, you can make them match the size of your numeric control, your numeric control callback reads the value, compares it to the permitted boundaries, and sets a LED on or off. Something similar to the picture below. Instead of off you can also change the color of the LED, say to green....
(5,432 Views)
Thanks for the recommandation, since I won't know the exact value is, two LEDs probably good enough.
And do you know there is up/down arrow can be used for LED control? I only see round and square shape
for the LED.
(5,428 Views)
Accepted by topic author lynnz
you can resize the LED and change both their height and width...
(5,413 Views)
I'm going to use LED with round shape. Thanks
(5,385 Views)
