LabWindows/CVI
oval image
hey,
if  I want to copy from image, rectangle image an oval part to int val,
and then to put it on a canvas with canvasdrawoval, how can i do it?
when I'm using canvasdrawoval, it's only gives me options to put the fram or the interior (or both),
but doesn't give me the option to draw an oval image or any image.
thank's for your help
(3,863 Views)
Stud24,
The Draw Frame option refers to the outline of the oval while the Draw Interior refers to drawing a filled in oval. I believe you are looking for Interior (or both) to draw the whole in image.
You may benefit from exploring the provided example, canvas. You can find it by going to Help»Find Examples; from here select 'Directory Structure' as the Browse according to option in the left pane and in the middle pane select userint»canvas.csw
(3,844 Views)
