LabWindows/CVI
pass labwindows cvi files to labview files
hello everybody.
i have an application build in labwindows cvi, but we want to change of platform(labview), how we can pass or covert from CVI to labview.
it´s possible this thing.
thanks for you help.
see you!!
(2,983 Views)
hello, I'm not sure why nobody answered you question, maybe because it is beyond the scope of what can be explained in this forum's format?  Personally, I know of no way to directly convert a LW/CVI app to run in LabView.  However, when building your CVI app, you can designate a dynamic link library as the target type, and as I understand it, LW/CVI DLLs can be used in LabView applications.  There are a number of pieces of NI example code, application notes & tutorial documents you might want to familiarize yourself with before going this route, among them the following:
1) basic DLL in Labwindows in the CVI examples directory of your installation,
2) NI Application Note #80, Creating Reusable Test Code for LabVIEW, Visual Basic, and C/C++ with LabWindows/CVI.
3) NI Application Note #207, Using LabWindows/CVI DLLs in LabView Real-Time Applications.
and,
#4) The NI tutorial entitled, An Overview of Accessing DLLs or Shared Libraries from LabVIEW.
Good luck,
aj
(2,967 Views)
