LabWindows/CVI
pass text messages to excel file
Dear Sirs:
I'm trying to communicate my LAB applicatiob with an excel file.
I have no problems to Read from excel or write to excel numeric values but I am having a lot of problemns to write in excel text messages.
For example:
In a text box I have the messagge " hello i am working "
How can I write this text box line in the A1 cell of excel worksheet?
And then How can I read from exce?
Best regards
Eneko
(3,303 Views)
I have attached a file with some code I wrote to do several things using DDEServer functions. Also, here is a good website summarizing many Excel commands: http://techonthenet.com/excel/formulas/. Also, look in the CVI samples directory for activeX projects. Many of them are specifically for Microsoft application control.
Hope this helps
(3,281 Views)
It may be as simple as ensuring correct data type is specified.
For example I use the "Excel Report" function panel (..samples\activex\excel\excelreport.fp) and this line:
ExcelRpt_SetCellValue (ws_handle, cell, ExRConst_dataString, outstring);
So, having read the text box string into your character array "outstring", the above line should work. Note you need "ExRConst_dataString", not "ExRConst_dataDouble".
Hope this helps.
--Ian
(3,279 Views)
