LabWindows/CVI
passing variable number of arguments to function
He,
I would like to create a function like this:
//prototypes
void out_print(char * format,...);
void start(void);
//function with variable number of arguments
void out_print(char * format, ...)
char buffer[512];
Fmt(buffer,format, ...); //this doesn't work!!!
SetCtrlVal(panelHandle,STRING,buffer);
//some function calling out_print
void start(void)
int size;
//do some stuff
//get the size needed, for example 65000
size=65000;
out_print("file : %s, size: %i", "myfile.bin",size);
//do more stuff
How can I pass the variable number of arguments from the out_print function to the Fmt function? I have read it should be something with the macros va_list, va_start and va_end but I couldnt figure out how exactly to do it. A problem is also that the arguments of print_out may be int, double, char *, ... in any order.
Thanks for the help!
Kristrio
(4,194 Views)
Here some hint to design and use a function vith variable number of arguments (by means of va_xxx macros you already mentioned). I used this function to create a history of operation in a plant controller: depending on the type of event to record, there were different parameters to store.
// Types of parameters passed to the function (see "stdarg.h")
#define INTPRM  1
#define DBLPRM  2
#define CHRPRM  3
int parms[10];   // Array of arguments for History ()
// Function definition
void History (int op, int stn, int *parms, ...);
// USAGE: Record and event in program history
// HINT: always add a parms[x] = 0 at the end of the list!
parms[0] = INTPRM; parms[1] = DBLPRM; parms[2] = 0;
History (id, op, parms, data1, data2);
// History () function
// This function writes resord in program activity list
// This function accepts and handles a variable number of arguments
void History (int recordType, int station, int *parms, ...)
 int  fH, error = 0;
 char type, msg[256];
 SYSTEMTIME lt;
 va_list ap;
 // Start variable parms handling
 va_start (ap, parms);
 // Open history file (handle file I/O error)
 // Date / time of record
 GetLocalTime (&lt);
 sprintf (msg, "%02d/%02d/%04d  %02d:%02d", lt.wDay, lt.wMonth, lt.wYear,
  lt.wHour, lt.wMinute);
 sprintf (msg, "%s,%s,%d,%d", msg, operator, station, recordType);
 // Variable list of parameters
 while ((type = *parms++) != 0) {
  switch (type) {
   case INTPRM: sprintf (msg, "%s,%d", msg, va_arg (ap, int)); break;
   case DBLPRM: sprintf (msg, "%s,%.1f", msg, va_arg (ap, double)); break;
   case CHRPRM: sprintf (msg, "%s,%s", msg, va_arg (ap, char *)); break;
 // Write to file and close it (handle file I/O error)
strcat (msg, "\n");
Error:
 CloseFile (fH);
 // Stop variable parms handling
 va_end (ap);
 if (error) {
 // Error handling
 return;
Hope this helps you a little
Roberto
(4,188 Views)
Thank you Roberto.
I managed to do what I wanted to. In attachment my code for the ones interested.
Cheers,
Kristrio
(4,178 Views)
On my side I use this kind of simple function. this allow to add text in the text box.
I have also a variant with rich text box.
Bext Regards,
int UI_Printf(char *form_str, ...)   /* a printf emulation  ! */
 va_list list_arg;
  char    strbox[500];
  int  iTraceFileHandle = 0;
 strbox[0]='\0';
//  translate form_str with list_arg into str
 va_start(list_arg, form_str);
 vsprintf(strbox, form_str, list_arg);
 va_end(list_arg);
SetCtrlVal (uiPanel, UI_TEXT_BOX_INFO, strbox);
ProcessSystemEvents();
 return 0;
(4,118 Views)
This code is indeed much easier than mine. Thank you!
(3,967 Views)
