LabWindows/CVI
pb refresh
my application works fine except a pb : panels are not well refreshed.They use CWGraph activeX.After few days the plot are not refreshed.I need to close and re open the panel to see my data. Even CVI panels have a pb. What can I do ?.
(3,660 Views)
Can you post a simple example of programming which reproduces this behavior?
Thanks in advance.
Matthieu Gourssies
national Instruments France
(3,660 Views)
Unfortunatly no because the application is big.I use 4 panels and each panel have a CWgraph inside. The pb seems to come after a long time ( after at least 2 days or may be a lot of datas ? ).I think I don't have that pb with Windows2000 (I'm not sure).So I try to use refresh function of Graph object each time I plot new datas.But what is very odd is that even CVI panel without graph have the same pb.
I use the following settings for the graph activex :
* control refresh : immediate
* chart style : strip chart
* history : fixed : 20000
My application have to work continously.Is that correct ?.
Thank you
(3,660 Views)
Comment savoir si j'ai la dernière version de CWGraph ?.
(3,660 Views)
