LabWindows/CVI
pci bus access
ViStatus viIn8Ex(ViSession vi, ViUInt16 space, ViBusAddress64 offset, ViPUInt8 val8) <= viIn8Ex is in the documentation but I get an error when I attempt to used it.
How do I access an external board on the PCI bus which uses a PLX 9656.  I want to access the local bus which starts at PCIBAR3?
(3,829 Views)
ekatana, I have a few questions.  What is the error you are seeing?  Is there a code associated with it?  Is the documentation you are referring to the NI-VISA Programmer Reference Manual?
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(3,814 Views)
Error is "missing prototype".
viIn8Ex is listed in the help file.
Code snippet:
 viIn8Ex(pxi9656, 0, VI_ATTR_PXI_MEM_BASE_BAR3, (ViPUInt8)myLoc);
(3,808 Views)
it may be that you forgot to #include a file in your source ? maybe...
(3,781 Views)
You will need to add #include "visa.h" at the top of your .c file to reference the VISA library.
Ben
(3,759 Views)
