LabWindows/CVI
pci dio cvi code
Hello does anyone have a sample code to drive a NI PCI DIO 96 using lab windows 8.0 or later?
(5,412 Views)
Hi FrankDM,
Depending on which driver you have installed (NI-DAQmx or Traditional NI-DAQ (Legacy)), you will have example code available. If you have the NI-DAQmx driver installed, you can find example code in LabWindows/CVI  >> Help >> Find Examples. If you have Traditional NI-DAQ this article should outline where to find those examples: http://digital.ni.com/public.nsf/allkb/868ED9971759DDC886256D3500743166
The manual for your PCI-DIO-96 should have more specific coding information for the device. Here is the manual: https://www.ni.com/docs/en-US/bundle/pci-dio-96-pxi-6508-pci-6503-feature/resource/374938b.pdf
I hope this helps!
Rachel M.
(5,385 Views)
