LabWindows/CVI
peak decimate
Hello Everyone,
Im writing a function that does a peak hold decimate of an array. The decimate function supplied with CVI is very fast but does averaging and someting else, not peaks. The routine I have written does the job but it is very slow. Is there anyway I can access the C code of the CVI decimate function and modify it for peaks instead of averages?.
Mike
(3,148 Views)
Hi Mike.
Maybe what you need is the PeakDetector() function (from the Advanced Analysis library).
(3,138 Views)
